About the supposed mechanical issues with the engine? Yes.And the purpose of pointing this out is to tell me to run 5w30? Or was the purpose just to tell me that I'm wrong?
It’s funny that you trigger off something that’s easily disproven. Use whatever you want, but don’t perpetuate something that’s disproven in the owner’s manuals.No. If this bugs you SO much to pick out ONE singular assumption that I made just so you can tell me I'm wrong you need to find a different hobby because....
I'm not playing this game here, I know this place better than that. We'll have a 20 page thread about CD and AFM and VCM, cam event timing, oil viscosity, and how everything everyone says or knows is wrong on some level or in some small way that completely invalidates everything they've ever done in their lives and buried somewhere in it will be 2 or 3 good posts about using oversize vs standard size oil filters and which oils are currently the best for DI engines.
So. Let's stay on topic, ok? I already said I'm going to use 0W-20 engine oil and I already said why I'm going to use 0W-20 engine oil. If this bothers you oh so very much you're welcome to sneak into my garage and change my oil to 5w30 just to prove me wrong so you can give me the big "I told you so". Got it? Ok good. Let's move on.
On the newer Mazda's like mine the only limiting thing can you get the filter under the belly pan!It’s funny that you trigger off something that’s easily disproven. Use whatever you want, but don’t perpetuate something that’s disproven in the owner’s manuals.
There’s zero difference in the engines that have VCM or other technologies that call for Xw20 in the US and those same engines overseas that allow for say Xw40 or Xw50. There are several OMs that have wording similar to “in high temperatures or sustained high-speed operation, a heavier grade may be required for sufficient engine protection.”
So this wasn’t a knock on 5w20s; I’ve run it in my older Fords. I’ve got 5w20 from HPL in my 2.0 Mazda-powered Transit Connect. But I’d also run an Xw30 in it without thinking anything untoward would happen.
And yes, the 14610 size is fine if you’ve got clearance and the can doesn’t hang down into the path of road debris. Hope you enjoy your new ride, I always liked the “Zoom Zoom” commercials.![]()
You say you are going to stick with 0-20 oil for warranty purposes but are going to use some other filter. If you are worried about warranty, why not use Mazda filters??I finally got my new 2023 Mazda 3 2.5 base model after a 6 month production backlog. I've put about 350 miles on it and was planning on changing the factory fill at 1000 miles because no particular reason other than I'm 'old school' and worry about break-in/production debris in my new engine. I realize I'm probably just throwing away a perfectly good oil filter and oil but it's a cheap price for a little peace of mind.
According to Mazda 0W-20 for US and 5w30 for the rest of the world, I'll stick with 0W-20 since it's got cylinder deactivation which relies on oil pressure to run that system and likely is tuned for the expected properties of 0W-20 oil.
My first question comes in at which filter to run. The OEM filter is equivalent to a Purolator 14612 size (68x65) but there's a 14610 size (68x85) that's the same gasket diameter, same thread, same bypass pressure, just a taller filter by 20mm. Filter sits behind the engine at a downward angle so I'm not concerned about it being low hanging fruit, if I hit the filter on something then I've also smashed the car bad enough that a dented filter is the least of my worries.
Is there any reason NOT to run the larger filter? They're the same price. I don't gain any significant oil volume. I get a little bit more filter area. Warranty might be at risk if I had an engine issue crop up?
2nd question, this is my first vehicle with DI. I haven't seen much about Mazda having fuel dilution issues or carbon build up issues with their PY-VPS 2.5 SkyActiv G engine. Other than drive it and change the oil every 5K miles or so is there anything I should be aware of or do differently or keep in mind not to do? I already know that generally frequent short cold trips and DI are not great and lead to fuel dilution, I see this on DI cars owned by older people at work often enough so we just do shorter OCI's on those vehicles. My typical driving schedule should be fine to avoid that, a good dose of highway and a little stop and go on. Should I get an aftermarket catch can to further reduce the risk of carbon build up or is that a myth that those help with that? I'm planning to keep the vehicle past 100,000 miles.
The outgoing Mazda 626 (FS-DE) clocked up to 208K and that engine runs like a tappy top with strong cross hatch still on the cylinder walls. It got 0W/5W/10W-30 Sythetic from Valvoline or Mobil and a PureOne filter every 5-7K miles for the past 120,000 miles. I'm hoping the new car can do the same long run for durability.
Curious minds would like to know why Mazda filter and oil on the first change but it really won't matter after that? My first change was to Mobil 1 Extended Performance and my second to Quaker State. Didn't seem to make a difference. The UOA I took after the first change came in right as I expected. I fact the only reason I took one I wanted to see if I was having a fuel dilution issue.For your first OCI use a Mazda filter and Mazda oil. After that, use whatever you want, it really won't matter...
It was a stupid answer to a stupid question. Frankly, any oil or filter will be just fine. Even for the first OCI.Curious minds would like to know why Mazda filter and oil on the first change but it really won't matter after that? My first change was to Mobil 1 Extended Performance and my second to Quaker State. Didn't seem to make a difference. The UOA I took after the first change came in right as I expected. I fact the only reason I took one I wanted to see if I was having a fuel dilution issue.
Years ago, Jeff Jetter of Honda R&D mentioned something about viscosity and their engines. I forget exactly what he said but it had to do with using grades that are higher and have negative implications on operation. It is interesting though how in many parts of the world multiple viscosities can be used in certain engines per owner's manual. I don't know enough about to have an opinion one way or another.View attachment 188219
It uses a collapsing hydraulic lash adjuster style cylinder deactivation scheme which uses oil pressure to either keep the lifter pumped up and valves opening or it allows the lifter collapse and valves to not open. Since this uses oil to accomplish the feat and since it's critical to have the activation and deactivation timed to the position of the cam to avoid slamming the roller into the wrong part of the lobe and potentially causing damage I assumed that Mazda takes into account oil temperature then assumes viscosity and likely is timing the system on some assumptions for best performance. I read some technical papers about AFM failure in GM LS engines and one of the theories is mistimed lifter reactivation causing high loading on the roller and bearing leading to bearing damage and brinelling of the roller and lobe and then eventual failure of the roller and lobe surfaces and we all know how that goes. Tap tap tap chirp chirp chirp goes the neglected LS.
As for the oil viscosities themselves, I pulled that from AllData which probably got that information from Mazda as seen above. A little weird they don't call out an API oil spec for engines with CD at all, looking at spec listed for non CD engines it's the same ILSAC GF-V for the US but shows API SM for the rest of the world.
We just got a 2024 Mazda CX-5 a week ago. Not even in the parts catalogs yet, so I'm not sure what filter even goes on it. It's not a turbo. SHould be same filter as the 2023 non turbo, right? I don't think the engines changed?
Is there a specific reason, other than Mazda giving me a hard time about warranty if it went in with a taller filter, that I should not run a taller filter if it seals the same and has the same bypass pressure?
