I finally got my new 2023 Mazda 3 2.5 base model after a 6 month production backlog. I've put about 350 miles on it and was planning on changing the factory fill at 1000 miles because no particular reason other than I'm 'old school' and worry about break-in/production debris in my new engine. I realize I'm probably just throwing away a perfectly good oil filter and oil but it's a cheap price for a little peace of mind.
According to Mazda 0W-20 for US and 5w30 for the rest of the world, I'll stick with 0W-20 since it's got cylinder deactivation which relies on oil pressure to run that system and likely is tuned for the expected properties of 0W-20 oil.
My first question comes in at which filter to run. The OEM filter is equivalent to a Purolator 14612 size (68x65) but there's a 14610 size (68x85) that's the same gasket diameter, same thread, same bypass pressure, just a taller filter by 20mm. Filter sits behind the engine at a downward angle so I'm not concerned about it being low hanging fruit, if I hit the filter on something then I've also smashed the car bad enough that a dented filter is the least of my worries.
Is there any reason NOT to run the larger filter? They're the same price. I don't gain any significant oil volume. I get a little bit more filter area. Warranty might be at risk if I had an engine issue crop up?
2nd question, this is my first vehicle with DI. I haven't seen much about Mazda having fuel dilution issues or carbon build up issues with their PY-VPS 2.5 SkyActiv G engine. Other than drive it and change the oil every 5K miles or so is there anything I should be aware of or do differently or keep in mind not to do? I already know that generally frequent short cold trips and DI are not great and lead to fuel dilution, I see this on DI cars owned by older people at work often enough so we just do shorter OCI's on those vehicles. My typical driving schedule should be fine to avoid that, a good dose of highway and a little stop and go on. Should I get an aftermarket catch can to further reduce the risk of carbon build up or is that a myth that those help with that? I'm planning to keep the vehicle past 100,000 miles.
The outgoing Mazda 626 (FS-DE) clocked up to 208K and that engine runs like a tappy top with strong cross hatch still on the cylinder walls. It got 0W/5W/10W-30 Sythetic from Valvoline or Mobil and a PureOne filter every 5-7K miles for the past 120,000 miles. I'm hoping the new car can do the same long run for durability.
