Originally Posted By: car51
point is I don't, and wont use one. good enough answer for me and others here, so that's what matters. Kind of like when you say a tough guard or ultra isn't good enough like a Purolator somehow is eh?
No need to get so defensive. You were making comments about how this filter would be prone to tearing based on its construction. I simply asked you to quantify that somehow. To explain what about the construction clearly made it prone to failure. You were unable to, so it is only safe to assert that there is, in fact, no way to definitely tell based on its construction that it would have failed. Don't take things so personally guy, nothing personal, just business right?
Second, you may be misremembering, but I have always said the Ultra is the only from filter I would use, and currently have two in service that I plan on doing a compare / contrast article between them and the Purolator synthetics.
Oh yeah, I have cut more that are TORN so you know. I will also stick with Zee0Six and other "more knowledgeable members" who accept that Purolator has NOT fixed this problem to this very day. thanks for adding nothing to a otherwise informative post
Your post was in no way informative. Making blind assumptions that cannot be validated are much less than "informative".
If you would rather listen to zee and other "more knowledgable members" (aka people that agree with you) go ahead. But if you make a point, you should be able and expected to defend or explain it just like anyone else here.
As far as the Purolator problem that may or may not exist. Have there been some filter failures? Sure there have been some reports of torn media. I won't deny that. Never have. I maintain the point that it was a combination of a small (one year or so) bad production run and people using these filters in ways they were not designed to be used. Having said that, I would bet money that the filter you cut open could have been used for a 5k mile OCI just fine and not been any worse for the wear. I think its construction proves that. So once again I leave the question open, without getting flustered, making personal attacks or deflecting, how does this particular filters construction prove it would have failed?
