I am building a street sleeper 383 for my 1967 Camaro.
Looks like a 350, runs like a Monster. Typical Economy type Grocery Getter.
The engine is a mild 383 (6.27 liter)
(5.7 liter-350 cu in block, with 4.030 bore
and 3.750 in stroke)
The Engine has 10-1 compression
MAHLE forged pistons flat tops SBC-425030F05. +
Eagle 5.7 H-Beam Connecting Rods
Forged Summit One Piece Rear 383 Crank
AFR 195 Eliminator cylinder heads
Comp Cams Pro Magnum SS Full Roller Rockers.
Comp Cams Pushrods
Comp Cams Hydraulic Roller Cam
.536 intake, .544 Exhaust 110 Separation
Comp Cams Hydraulic Roller Lifters
Crane Rocker Stud Girdle
AFR HydroRev kit to keep the lifters in their holes
The intake is an Edelbrock Performer RPM AirGap
BG Demon 750 AV Carb (650 cfm)
The Distributor is a Mallory Unilite
1 5/8 in headers with 3"Collectors
The Transmission is a 4 speed Muncie Transmission.
CSI Electric Water Pump
100amp Alternator
The 12 bolt rear end is 3.73
The tires are 225/60VR15
I want to run Synthetic oil in the Monster, but I have been told I have to use DINO oil during break-in, and then I can switch to Synthetic. How long should I wait, and what do you recommend for break in, and until I start using synthetic
