Donald
Yes, DC should work (was one of the options listed by Cisco).
My concern is that you are powering a switch over PoE at a pretty good distance, which is then in turn trying to power multiple AP's over PoE, that's a huge draw when you consider you are doing it over 23 or even 24 gauge wire.
If that switch itself was powered directly (not over PoE) I wouldn't have the same level of concern, but this is a pretty taxing setup.
Startech makes some industrial grade power injectors that are designed to be DC-fed:
Industrial Gigabit PoE/PoE+ Injector 30W - Ethernet Extenders | Networking IO Products | StarTech.com
Industrial Gigabit Ethernet PoE Injector 30W 802.3at PoE+ Midspan 48V-56VDC Power Over Ethernet Injector Adapter -40C to +75Cwww.startech.com
One of those for each AP fed from a solid DC feed and you'll eliminate the load on that switch.
Can this go in an outdoor enclosure? That is part of the issue.
