MetalSlug
Well I got him a 2015 Nissan Frontier SV look clean
This happened to me. I really liked the truck for what it was but the trans/coolant problem of course soured my experience. It's hard to call them "trucks" but for what they are I think they are great.The 4.0/5AT is hard to beat for durability. If you get a 2012 or older , change the radiator as it will mix transmission fluid and coolant. They're good little trucks! Transmission and rear differential are the same as in the Titan. Frame is smaller 1G titan frame. The rear axle is narrowed but same differential.
Biggest problem was 05-10. A few lingered in 11. I replaced the one in my 10.This happened to me. I really liked the truck for what it was but the trans/coolant problem of course soured my experience. It's hard to call them "trucks" but for what they are I think they are great.
https://jalopnik.com/by-the-numbers-2015-chevy-colorado-vs-tacoma-frontier-1639032173The ridiculous turning radius is a thing with them too. I've put quite a few miles on my FILs 2017 Nissan Frontier crew cab, long bed 4x4. I think my 2019 Ram 1500 classic can turn a circle inside the Frontier's circle, that's how bad they seem. Once you get used to that, it's not much of an issue.
At one time they were the #1 traded in vehicle within a few years.
I suspect people didn't realize small trucks usually do not get much better mpg than the rest.
I like them myself
I had forgotten about the turning radius. You are right, my truck was the king of 3 point turns, like driving a tractor trailerThe 2011+ Frontier is probably the best vehicle Nissan has made in terms of reliability and longevity. They even tend to hold up well in the rust belt.
Like said above, I think people get a bit dismayed with them because their fuel consumption is quite a bit worse than the average full sized V8 powered 1/2 ton pickup.
Turning radius was the only drawback for me. My PT Cruiser was terrible also.I had forgotten about the turning radius. You are right, my truck was the king of 3 point turns, like driving a tractor trailer![]()
Jeepers... here I was thinking I was king for a day with a just slightly smaller turn radius and a mixed, real world MPG average of 16.4 on a Chevy 6 liter. With a clunky, old skool 4spd. auto-overdrive w/4.10 final gear ratio on top. (5300lbs. Curb weight)
Sheesh, just do what my neighbor did. He swapped his 2019 RAM 1500 5.7 HEMI for an 97 Silverado Ex cab short bed w/190kMiles on it. Better fuel economy, no tickity-click-knock-knock-knickity-knock of dewmbriningsorzerz.
Despite age, milage and dry, flaking paint? To him that old 350 TBI is a much better value.
Sometimes, to go forward? One must go backwards. Old iron Chevrolets, forever!![]()
No, he still has both parked in his driveway. While I was busting knuckles swapping U- joints in my truck, I stepped next door for a hello, howdy-do.16.4 mpg is great for that truck! I don't think my FIL has ever seen better than 17mpg tank to tank with his 2017 Frontier.
I hope that wasn't an even swap for you neighbor. Good lawd..
He was washing the Ram and I helped him repair a rear power sliding window gasket in his back cab window. He's going to put a sign on it and park it out at the end of the boulevard soon. ^.^
He hasn't said why he's selling a barely 3 y.o. rig like that but I suspect he's been internet reading. His 5.7 HEMI has that dreaded tick of doom, but still runs good. I think he's making it someone else's future headache.![]()
None at all, fortunately. It was askew in a manner that would cock the sliding glass pane and prevent it from fully closing. It was whistling like a boiling over tea kettle at highway speeds!Was he chasing a water leak in the cabin by chance w/ that rear window gasket?
A great point, but not the issue. I sneaked a peek while he had the hood up. I've got a GM 6.0 that pops collector bolts like a movie house pops corn, it's no trick at all to figure out what's going on with a glance. The heat shield and heads were just like they were factory machined, not a hint of carbon tracks and blow by. But when it idles at full hot, kneel by the passenger front tire and you can hear a pronounced tick and low, dull thud.I've not heard of one as new as a 2019 be effected by cam/lifter issues. He may have a broken exhaust manifold bolt(s), but on some of the newer ones like my 2019 Ram 1500 classic w/ hemi, they added tie-bars between the bolts and manifolds. So I guess now instead of the bolts breaking, the manifolds will crack. LOL.
And VW sells the most stylish junk on the market. Some things never change.Nissan and Toyota sell the best new 15 year old trucks on the market.
My 20 Ram 5.7 does the same. The “thud” sound occurs randomly. I have always chalked it up as normal operation. There was probably nothing wrong.A great point, but not the issue. I sneaked a peek while he had the hood up. I've got a GM 6.0 that pops collector bolts like a movie house pops corn, it's no trick at all to figure out what's going on with a glance. The heat shield and heads were just like they were factory machined, not a hint of carbon tracks and blow by. But when it idles at full hot, kneel by the passenger front tire and you can hear a pronounced tick and low, dull thud.
But how can you see all of that fine engineering and style if the head liner is constantly in your face? J/K....And VW sells the most stylish junk on the market. Some things never change.
I think you're the first person to ever call a VW stylish.And VW sells the most stylish junk on the market. Some things never change.
