OEM replacement via WIX
Part Number: 57060
UPC Number: 765809570603
Principal Application: Various GM, Saturn, Saab (07-08)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.430
Outer Diameter Top: 2.970
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 15
Anti-Drain Back Valve: Yes
Beta Ratio: 2/75=10/25
Max Flow Rate: 10-12 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.750 2.410 0.270
Larger diameter - longer - slightly higher bypass valve setting
art Number: 51592
UPC Number: 765809515925
Principal Application: Cummins, Komatsu, Onan Engines
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.214
Outer Diameter Top: 3.663
By-Pass Valve Setting-PSI: 18-20
Burst Pressure-PSI: 250
Max Flow Rate: 11-13 GPM
Nominal Micron Rating: 16
Gasket Diameters
15614 2.834 2.462 0.255
Same basic deal
Part Number: 51087
UPC Number: 765809510876
Principal Application: Ford European-Dorset Engs.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.477
Outer Diameter Top: 3.661
By-Pass Valve Setting-PSI: 19
Burst Pressure-PSI: 355
Nominal Micron Rating: 24
Gasket Diameters
Attached 2.834 2.462 0.200
Gasket Diameters
If your filter is recessed, then I think you're out of luck. If not, then you have options assuming you can fit the diameter. The gaskets will work.
