WIX Filter # 51715 cross or longer/shorter option help
in the shop
Hoping someone can help me out with this. I'm not having any luck searching the inter web trying to find a filter that is either slight shorter or longer than what this Wix filter is. I have plenty of room to use a much longer one if needed. These Wix filters are about $50 each. Many other hydraulic filters that are similar, or larger, are half the cost. Preferably a quality brand name filter. TIA
Specs:
40 x 2.0 mm thread pitch
7.6 x 4.7 x 4.6 in
That's a big hydraulic oil filter. My digging around shows any others that cross to that filter are also pretty expensive, some over $100. Might find some down in the $35 range.
Yes thanks for looking. I tried search thread sizes but couldn't find much. I'm wondering if it has to do the thread pitch. Perhaps it's not very common. I found for china knock off's but I'd rather just stick with the Wix branded or even the OEM is South Korean made for my LS tractor.
Thanks Bighorn, I've found a couple of those as direct cross reference swaps but they are more expensive. I was hoping to find something that wasn't on the direct cross chart that would still be compatible and with a cost savings. I'm starting to think that this unicorn does not exist. I agree though, I'm not going to use a china knock off filter to save $15.
