Need help with larger oil filter selection
Florida
2007 GMC sierra CLASSIC 6.0
Currently it has a PH-48 delco filter. It's no where to be found locally. At all.
A Purolator P12222 is equal to the PH-48.
I'm looking for a larger Purolator PureOne that will fit? how do I figure it out without having to buy 50 filters?
I think you mean PF48 ..a PH48 is a 3/4-16 thread filter
Purolator has no knowledge of your P12222 (assumed to be PL12222 of which they seem to only list L12222)
Your current filter in Wix
Part Number: 57060
Principal Application: Various GM Vehicles (07), Corvette (06-07)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.430
Outer Diameter Top: 2.970
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 15
Anti-Drain Back Valve: Yes
Max Flow Rate: 10-12 GPM
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.750 2.410 0.270
Other filters that share the same or near same gasket size and the same thread in WIX (xref'd from Donaldson)
Part Number: 51087 (PL30238 may not exist L30238)
UPC Number: 765809510876
Principal Application: Ford European-Dorset Engs.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.477
Outer Diameter Top: 3.661
By-Pass Valve Setting-PSI: 19
Burst Pressure-PSI: 355
Max Flow Rate: 11-13 GPM
Nominal Micro Rating: 24
Gasket Diameters
Attached 2.834 2.462 0.200
Part Number: 51592 same number (PL30238 - may not exist- L30238)
UPC Number: 765809515925
Principal Application: Cummins, Komatsu, Onan Engines
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.214
Outer Diameter Top: 3.663
By-Pass Valve Setting-PSI: 18-20
Burst Pressure-PSI: 250
Nominal Micro Rating: 16
Gasket Diameters
15614 2.834 2.462 0.255
Why do you want a bigger filter?
How about a better one that filters better, flows better, retains more particles, and lasts longer?
Which truck is yours?
- SIERRA 1500 PICKUP
- SIERRA 1500 HD PICKUP
- SIERRA 2500 HD PICKUP
- SIERRA 3500 PICKUP
Psssttt... Tim... Look at his signature file for your answer...
I have always gone with a larger filter on all my vehicles.
The PF-47 goes to a PF-52. I use that on my wife's car. It's about 25% larger than the 47.
On the 2004 6.0 gmc I used a M1-206 / PureOne PL25288 to replace the PF-46?
On the 07 I'd like to find a larger PureOne/Mobil 1 that's equal to the PF-48.
From the post above with the thread at 3/4-16 . How would i go about finding this on the shelf at the local Autozone?
You're looking for a 22Mx1.5 thread. The difference between that and a 3/4-16 thread is the difference between PF48 (AC DELCO) and PH48 (FRAM)
Your longer Purolator is a L30238 ..and if they make one, the PureOne would be PL30238.
