I have a Honda gx200 that powers my home made welding machine that uses an ACdelco DR44 alternator. It works great. Main problem is when I run about 120amps the engine loses speed. Turning it down to around 110amps gives reliable steady welding power.
Other small problems are the welding alternators field current is provided by a 12v battery, that battery goes dead after a while and on hot days the heat sink for the bridge rectifier gets pretty hot after I run it for a bit even at 100 amps. The old battery I'm using takes at least 2 hours to recharge.
For the hot heat sink the easy answer is add a fan or fans, but that will kill the battery even faster. Running a bigger engine will allow me to run 120 to 150 amps so the heat sink will get hotter faster and it will absolutely need fans. So I'm thinking adding a second normal, small 12v alternator.
Upgrade engines I'm thinking about going to are an 8hp predator 301cc or stealing my freshly rebuilt Honda gx390 engine off my pressure washer.
I'm thinking adding a 2nd small 12v alternator even if that alt has an underdrive pulley it will rob at least 1hp. So the 301cc only ends up giving me one to one and a half additional HP to drive the welding alternator, maybe giving me 130amps max.
I'm thinking in this case bigger is better and go with my hot gx390.
Or do I need something even bigger?
