I'm Looking for an oil recommendation. I have a late model Camaro SS with an A6 automatic my car has been given an LS3 conversion. Its been Cammed , milled heads ( higher compression ) Ls7 lifters , 3200 stall and etc
just 8 months ago with 9K miles on the odometer I had a lifter failure sending needle bearings into the oil pan through out the engine. This resulted in having to redo the engine.
block had to be honed to clean up scratches
heads had to be milled a little more to clean up surface scratches ( compression is now 11.5.1 )
New Cam
New Lifters
New oil pump ( Stock )
Etc
The guy who built the engine happens to work with a lot of force induction cars therefore he recommends Mobil 1 15w50
im guessing he buys it in bulk and recommends it for everyones builds ( I dunno )
So im using 15W50 mobil1
I live in Texas in the DFW area we have HOT ( 100+ ) temps in the summer Winters that range from 20's to 30's for 2 months out of the year at night with 50's to 70's during the day every so often we get some temps in the 30's however thats not to often.
Spring is mid 70's to lower 80's
My car was driven daily for a year now its a weekend toy. It visits the track 4 times a year other than that its driven back roads and across the state of Texas. When I do drive my car I do tend at times to DRIVE it with its tongue hanging out but thats not everytime I get behind the wheel.
My wife told me the other night her company gets a discount on Redline and Royal Purple. I thought about changing over to Redline since it has a lot more Zinc in it. I have asked a few people who have told me to go back to the factory 5W30 however I often wonder if going to a 10w30 would offer a little more protection with a thicker film.
obviously my engine builder wants a thicker oil ( something that will coat the internals while under use )
Here is my questions
first off
1. REDLINE synthetic would I be doing a good thing for my motor changing over to that from Mobil ?
I change Oil about 3K-5K miles. yes I know im probably getting rid of good oil but it makes me feel more comfortable especially since I went through a engine failure.
2. is 5w30 probably a little to thin for a motor with aftermarket cam with higher compression going through the engine ?
I know w30 means 30 weight and the first number is the cold number....
3. would I be ok with running redline 10W30 year around being given Great protection?
I had an oil filter magnet on my car when the castrophe happened my engine builder said he does not like those as they sometimes may remove to much out of the oil..... im wondering if thats the truth and mobil 15w50 isnt bad at all.
If I were to switch to redline what oil should I put in my car? I would like to stay with the same weight year around however if I have to switch in the summer as I do go to the track a few times then I can.
What are yalls thoughts ? Feel free to give your opinion no matter if its negative lol
Thanks for everything I look forward to your responses.
New Cam
New Lifters
Etc
first off
