As the title states - I need help buying the best value impact wrench for me (3/8" or 1/2" ?) ... I currently mostly work with 10mm to 21mm sockets in 3/8" drive (manual Craftsmen socket wrench) .
*What I find time consuming for oil and transmission maintenance are all the 10mm cover bolt / screws used to secure the under panel of my Hyundai Kia vehicles BEFORE you can even access the oil pan or transmission bottom ... Same goes for the 10mm bolt / screws used to secure the air duct dam just to get to the Throttle Body for cleaning or to spray intake valve cleaner into . *Since I already have 3/8" drive sockets I suppose that is the size battery powered impact wrench I need ? Which brand / model have you had good luck with for the types of jobs I describe above - but could also work for bigger jobs if required ? Thanks in advance !
