The car: 2003 Audi A6 2.7l twin turbo, auto transmission
The problem: I just recently had the car tuned to increase the boost and fueling, resulting in adding ~60hp and ~80lb/ft of torque. I also upgraded the diverter valves to accomodate the increased intake pressures so they don't dump the boost when they shouldn't. Now what is happening is I am getting 4 CELs for a rich condition at both idle and off idle, and on both banks. My tuner suggested I test for vacuum leaks.
I've pressure tested the intake system and found no leaks. I've cleaned the MAF, and I've changed out the coolant temp sensor both with no change. When I reset the CELs, the car performs great for about 20 miles and then the LTFTs get past their threshold and the car seems to revert back to stock boost levels. It never goes into limp mode and I can still drive it fine as is. From my research, rich at idle is typically a vacuum leak, and rich off idle is typically a MAF going bad. I haven't yet logged the actual numbers from the MAF, but will try to do that this week. The odd part is that right before I took the ECU out, I was running slightly lean at both idle and off idle so it would be strange timing to have the MAF fail at that exact time.
Anyone have any advice or similar experiences, I'd love to hear what you did to address these codes.
