`96 Ford with a 2L. Somehow I am getting both codes. The lean code always comes first, with the rich code either second or pending. For the life of me I cannot figure out where it is coming from.
The car has 131K. The last oil sample showed no bad signs of fuel in oil, sill was below Blackstone's recommendation actually. Anyway, fuel filter is new (yearly maintence), the upstream O2 was sluggish so it was replaced (both old and new showed ~.38v at idle. The exhaust system is stock, with the exception of a aftermarket muffler (though I dont see how that could cause any problems). Both the exhaust manifold to head and manifold to cat gaskets have been replaced (cracked manifold), so I know I am not getting air in there. Intake system is stock, and sealed up like it should be (again going off of the oil sample reading on silicon and my triple check). I know no air is sneaking in after the MAF.
As far as driveability goes, the car seems like it always has. If the rich and lean codes are pulled, the car still drives fine for about a day then the light comes back. If the computer is reset by means of disconnecting power to the ECM, the car is downright dangerous. Throttle response sucks. If you are stopped and go to WOT, pedestrians could beat it across the intersection. Part throttle is pretty much the same. You have to barely touch the throttle, until about 3K rpms and then you can get on it more. If you go past about 75% throttle, it falls on its face again. It will slowly get better as the car learns, but by the time it is almost back to normal, the light is back on.
With the light on, power seems normal. There is an off-idle stumble, the idle can fluctuate sometimes as much as 200 rpms in gear, sometimes its perfect. Rarely idles below 500 rpms (which seems low for a 4 cyl, at least to me), occasionally it will be stable at 400. There is also a flat spot in the powerband between ~5K and ~6K rpms.
I honestly cant remember how the car drives with the light off, but I am creeping up on emmissions quickly, and need to get it taken care of. I had thought it was due to the sluggish 02 and was waiting for funds to replace it. Now I have them, and its in, I need it off.
I am thinking (hoping?) that whatever is causing the CEL, will also cure the flat spot and the off-idle stumble. It would seem like it would if I am lean at one end of the powerband and rich at the other.
I have yet to pull vacuum readings, but have the ability if so requested.
Suggestions?
Suggestions?
