P0420 on 2004 rx330
2004 rx330. Had oil consumption issues when we bought it at 170k. I piston soaked it, cleaned valve covers, timing belt, etc. purrs pretty well now, stopped the consumption. Running Valvoline Restore and Protect 5w30. Does smell like exhaust / rich at idle on start.
There was a pending p0420 code yesterday. I hooked up a scan tool and unfortunately BOTH rear o2s are switching when the car is revd to ~2k.
I also think there's a small exhaust leak or two up front. The donut gasket fitting after the Y has some soot on the bottom, and I can smell exhaust at the drivers door.
I thinking of buying some used 2006 highlander cat/manifolds from a local salvage yard and re-gasketing everything forward of the Y. Manifolds are ~120$ each and are grade A used. 2006 did represent the cutoff to the better PCV system and less oil consumption.
The alternative is 4x the $ (walker or eastern - in Colorado I have to buy the carb compliant ones because of politicians), or Lexus OEM $800 each. Other option would be 02 spacers, and I really am not crazy about it, I would like to get rid of the fuel smell.
Ltfts are 4% / 9%.
If there is a leak before the cat, especially if it's before the last oxygen sensor, address that first. If you don't get another manifold or Y or whatever, try JB Weld muffler cement. If the cement holds up and the code doesn't come back, you saved yourself lots of money :)
If the code goes away, but the cement doesn't hold up, then replace the Y/manifold.
Make sure the manifold you get is from a 3MZ, unless Toyota used the same exhaust on the 2GR (unlikely). Toyota switched to the 2GR around that time 2006 :unsure:
If you live in an emissions county and you're for inspection soon, go now while the light is still off :D
I'm guessing he's not in an emissions county based on talk of spacers.
Friends with mailing address in neighboring state?
I didn't realize JYs could sell used cats. I mean, great if they can but I thought it was illegal.
This is an interesting thought, but they are all one unit. I guess I should clarify what the place that they wouldn't cut the cat off...
The issue I'm running into is because of the way the engine is mounted it's going to be a real pain to get to that rear manifold. So if I get in there to change the manifold gasket I really only want to be in and out of there one time. It's such a crazy design you can't see the entirety of the amanifold anyway, so I don't know that I would be able to confirm that there was a leak from that gasket itself. I suppose I could smoke it from the tail pipe and then watch in the engine bay...
