Hello everyone,
I recently bought a 96 Peugeot 406 1.8, didn't really need it but couldn't pass. It is litteraly like a brand a new car with 180,000 km on the odo. Single owner car who did everything himself and cleaned the car every time he drove it and stored it in his heated garage for 30 years. No leaks, no rust, no scratch, nothing. I like the car so much that I drive it as much as the Mercedes.
Anyway, fuel prices are insane here and like all of my cars, all it will see is E85. Original injectors are Bosch EV1 4 hole. I like to install bigger injector rather than rely on fuel trims to keep AFR as it should. What I had laying around was a set from a Volvo 740 or 940 2.3 turbo, they are also Bosch EV1 injectors with about +25% more flow but unless the original injector, they only have one hole with a pintle.
I'd like to know if the spray pattern will be an issue or not. I'm mostly concerned because this is a 4 valve per cylinder engine. I've discovered that a lot of older 4 valve engines using this type of injectors. I am thinking about tons of models from BMW, Porsche, Alfa Romeo and others. If it turns out I shouldn't be driving the car like that I can always find similar high impedance 250cc EV1 injector with 4 holes (Saab used them) or even EV6 injectors.
I switched to the bigger injector while I had a mixture that I think was about E35. Fuel trims were positive but not maxed out with the original injectors and negative with this set but the cars feels better than it did before, even when it was on E0 gas. The engine was always unresponsive around 2000 rpm and was slow to rev up to 4000 rpm before much feels better and now which is counterintuitive sicne I went from 4 hole EV1s to one hole EV1s.
