Well, it turns out that the injector o-rings aren't what was leaking on the 1988 Mustang 5.0.
I smelled gas again, and after wondering how I could possibly mess up an o-ring replacement, I asked my mechanic who stated that it's more common for the injector itself to leak than it is for the o-ring to leak.
So I added some UV dye to the gas (it's a VERY small leak)and drove it to work and back, and when I got home the UV light showed that the o-ring that I thought was leaking the first time around is actually the injector leaking where the plastic meets the metal. It also showed another injector leaking that I didn't even know was leaking.
So now I have decided to replace the injectors.
Most of the replacement #19 injectors seem to be "4-hole spray" injectors, instead of pintle spray which is what it has now.
Does anyone know what the advantages and disadvantages of 4-hole injectors over pintle injectors are?
From what I've been able to find out, they have better response time.
I've also found out that Ford no longer uses pintle injectors.
I've read conflicting information in terms of deposit resistance and spray pattern, with some saying that 4-hole is better and others saying pintle is better.
