"My warranty says that if I run SN/SM oil it will void my warranty and that I need to run conventional oil for the first 5000 miles. I'm looking for a 10w30 conventional oil high in ZDDP."
Your warranty is very specific. The Rotella T 10W30 conventional oil as i said in my earlier post is still sounding like the correct oil for you, rated SH, SJ, SL, SM. To cover your a$$ Email your re-builder and get his approval on the Rotella T, If he does not whole heartedly approve it then tell him you want him to name a specific oil you can use. When you have determined an approved oil from your re-builder use it for the first 5000 miles as specified and only buy the oil when you do the oil change and keep the receipts. Right or wrong that is the oil your engine rebuild-er wants you to use for the first 5000 miles, any deviation and he can void your warranty. After that you can can use the latest wiz bang synthetic.
You might also want to use a Pure One oil filter from Purolator.
