Originally Posted By: Chris B.
I bought them!
Congrats! As volvohead said, these are some of the most comfortable highway cars you will ever find. Also last winter I went through like 6 inches of snow on the highway and everyone was pulling over and the Volvo felt more in control than any 4wd I have had. It felt almost like there was no snow there.
Originally Posted By: Volvohead
The trick to being a long-term owner of a Volvo is to identify where those areas are, and deal with them proactively. The community of owners is good about keeping itself informed, and there is a large subculture of DIY owners. That philosophy, and regular fluid changes, are the keys to getting the multi-hundred thousand mile lives out of them.
This is the most important point I think. Spend some money up front to make sure all maintenance is up to speed and top notch, new, fluids are in everything (differential, transfer case, coolant, brake fluid, etc.). Then if you do regular maintenance they will last a long time.
Originally Posted By: mormit
Do your own work and you're fine. Otherwise, dealerships and shops will assume you like to spend money and try to take you for a ride. Be self-sufficient or don't be a sucker.
+1! A great way also to learn about your car and they are not hard to maintain once you learn what to do. A cheap $6 hand pump from an auto parts store helps with differential, transfer case fluid changing. I use redline in the transfer case and diff. due to high heat.
My recommendations in addition to those above:
1) Ignore Volvo's specs for any fluid where there is a long change interval. Change it like you should for any car and use high quality fluids. F. e. fush the transmission fluid every 30k (my general rule for any automatic). Volvo's recommendation for my xc is they call the ATF a "lifetime" fluid and say "visually inspect" the fluid on the dipstick. Ignore that and flush the fluid like you should and it will shift like new for a very long time. IPD sells transmission flush kits or you can make your own, it is easy to flush.
2) Use good quality gas like chevron, texaco, shell, not arco.
3) Keep all 4 tires the same brand/tire and same air pressure as this will avoid wear on the 4wd system. Should probably rotate regularly also.
4) Use leather conditioner on seats at least every 6 months or more often if possible. Keeps them from drying out and staying soft. Use natural oily or creamy products that don't leave a high shine, plasticy feel. I use zymol or mercedes benz leather conditioner but lots of good products out there.
Also IPD.com is a great source volvo parts/maint. stuff. +1 on the auto-rx recommendation. My car seems to really like german castrol but I haven't done a used oil analysis on it yet, i'll probably do one soon and post it.
