Need a good chaef guard for a coolant hose
Anyone know of any good chafe guards for hi temperature hoses? I need about 6in of chafe guard for a coolant hose about 1" in diameter. OD
I always like split loom for that purpose, but it can really be anything that will withstand the temps of a coolant hose. You could use silicone tape, or even electrical tape for that matter.
I take more hose the same diameter and slit down it lengthwise, as a "splint". This assumes there'll be a "safe side" and an "abuse side".
this.
to keep it in place, I use a couple of zip ties.
i use this method to protect any hoses or wiring that can/will rub on other parts.the split loom is good, as well.
this.
The zip ties won't melt?
I do this also. For hoses that site very close or actually contact the head I use hose clamps instead of zip ties.
this.
no,sir.been using this method for many years.
I do this as well, and if I am REALLY worried/OCD about abrasion, I put the split plastic loom AND the self stick silicone tape over that!
this.
You can buy zip ties that are made of stainless steel.
YEP! exactly what I did
