- Joined
- Jan 6, 2005
- Messages
- 10,291
It’s the natural color of the insulation foam. Painting it would add lots of weight with no functional benefit.Any reason for the turd brown center section not being white?
Depends on how you define budget. Medicare and Medicaid were not “ on budget” back then. And we’re tiny anyway where now there on budget and half of it.It is not a matter of technical competence, but a matter of resourcing.
NASA was given 10% of the federal budget to accomplish President Kennedy’s goal.
In today’s federal budget, that would be over $700 billion annually.
NASA is currently given 1/3 of 1% of the federal budget, and the fact that they can do anything at all on that little amount of money, relatively speaking, is amazing.
That’s a matter of opinionWell , yeah I get that . But why ? It seems like we have other priorities .
NASA's peak budget was in 1965 and the agency then got 5.25 billion dollars which represented 6.5% of federal discretionary spending, so not nearly 10%.It is not a matter of technical competence, but a matter of resourcing.
Whenever someone uses some non traditional measure my spidy senses tingle. Lies, dam lies and statistics so said Twain.NASA's peak budget was in 1965 and the agency then got 5.25 billion dollars which represented 6.5% of federal discretionary spending, so not nearly 10%.
You are right that NASA is now budgeted at around .5% (down to .35% as of 2026) of the federal budget and had a hair over 1% in the peak funding years for the shuttle.
That is an angle I had not considered and explains NASA's lack of visible programs over the past couple of decades.
That much we agree on .That’s a matter of opinion
Hal?If we need to learn more about the moon it seems a AI empowered robot is the answer. One way trip. No expensive “ circle the moon” test flights. They can roam around for months and see what they find.
How do you think AI felt about those Serfs ?Hal?
I wonder if the Artemis crew felt a little weird climbing into the rocket with AI onboard.
True.Regarding the need for human test pilots (and later astronauts), this quotation from the 1950s (when a mainframe computer was a massive thing that filled a room) is generally attributed to legendary test pilot Scott Crossfield:
"Where can you find another non-linear servo-mechanism weighing only 150 pounds and having great adaptability, that can be produced so cheaply by completely unskilled labor?”
There is nothing nontraditional about the means by which I characterized national Will. And that’s the real issue, there was a clear national Will to accomplish something and they put resourcing behind it as a percentage of federal budget.Whenever someone uses some non traditional measure my spidy senses tingle. Lies, dam lies and statistics so said Twain.
In the 60’s adjusted for inflation NASA budget was 2X current, peaking at 2.5X for a couple years. So yes a lot less now but back then they were doing everything for the first time, on a fast timeline, and as mentioned they did everything by hand calculation.
NASA has done some amazing things since, like voyager and Hubbell. If we need to learn more about the moon it seems a AI empowered robot is the answer. One way trip. No expensive “ circle the moon” test flights. They can roam around for months and see what they find.
NASA had the backing of the people because It was a national objective. Now it’s sort of a headline for a minute because it’s not the first time. Same as the Apollo program. After the landing the later projects were cancelled.There is nothing nontraditional about the means by which I characterized national Will. And that’s the real issue, there was a clear national Will to accomplish something and they put resourcing behind it as a percentage of federal budget.
A simple dollar comparison is specious and over simplified. A dollar today, whether we’re talking about commodity prices in the form of aluminum, or any other good or service has really literally nothing to do in the highly specialized world of Aerospace.
Dollar to dollar is a complete red herring. It misrepresents the difference.
Again, we were talking about the difference between the space program then and the space program now as a matter of national Will. Let’s look at the number of people that worked on the Apollo program. It was over 400,000 across NASA itself and the various contractors that were building the sub assembly.
Now, NASA is 18,000 people. Sure, there are contractors, but the “2 to 2.5 times the dollars” again fails to capture the magnitude of the contrast of level of effort and desire to go the moon between 1965 and 2026.
Look at the size of NASA itself, look at the size of NASA as a percentage of the federal budget. Those are meaningful comparisons, not dollars.
The meaningful comparison is not in pure dollars, when those dollars actually purchase very different things between 1965 and 2026 given the radical changes in aerospace design, capability, manufacturing, and materials across those years
Go to Kennedy and look at the Mercury capsules. It looks like something you and I would build in our garage using only stuff we found in the dumpster. If you put 4 wheels on it they would deem it unsafe or the bike path.I don't know of any deniers , but some things about landing on the moon with humans 6 times and making it back successfully
Make you go hmmmm... especially with technology they had at that time
There was one disaster, and some close calls in the Mercury, Gemini, and Apollo programs.I don't know of any deniers , but some things about landing on the moon with humans 6 times and making it back successfully
