Originally Posted by Trav
Quote
Flow through an oil filter will not be reduced if the PD oil pump is not in pressure relief, regardless of how restrictive or clogged the filter is. That's the whole key to this discussion.
That is the problem and where I disagree, the pump pressure relief functions when the filter is flowing properly and the oil is cold and thick and the rpm's are high creating over pressure in the system, it gradually bleeds off excess pressure. The filter bypass operates when pressure at the filter element increases due to contamination and can no longer full flow through the filter.
Yes, the filter bypass valve will open any time the delta-p across the filter is higher than the bypass valve setting - no brainer, we agree. But the filter bypass valve operates totally independent of the pump pressure relief valve.
Again, if the PD pump is not in pressure relief then it's still forcing all the oil from it's output side through the filter and engine. How can it not? That's just how PD pumps work.
If the pump is not in pressure relief then were does all the pump output flow go? You do realize that a PD pump output pressure will go sky high if unregulated because it literally forces/jams the oil downstream. Some of these pumps are capable of 300+ PSI if unregulated.
If the pump was not in relief and only putting out eg 30 psi but has a 90 psi relief and the filter was clogged to the point it cannot full flow the bypass in the filter will open as soon as the bypass pressure is reached. The pump pressure relief will not be reached.
True ... but if the pump is not in pressure relief (which you say it isn't in your example), then the total flow has not decreased. Only the filter bypass valve has opened, but the total flow through the filler and oiling system is still the same. That is the key to the whole discussion. Any time the pump is NOT in pressure relief, then 100% of the flow goes through the filter and engine. Where else would it go?
Quote
