NAPA Platinum vs Fram Ultra
The NAPA Platinum is made by Wix and is the same as the Wix XP and it is not a very efficient filter at all, despite having a synthetic media. I sent an email to Wix yesterday asking about the Wix XP efficiency and they told me it's 99% at 35 microns.
Not good. This is my Fram Ultra(Venza) with a 10k mi OCI( with a 5K OC)
[Linked Image]
Originally Posted by Patrick0525
On sale for $5. How do they compare against the Fram Ultra?
Are they 100% synth? Who is tha manufacture?
NAPA Platinum oil filter
One filter is pro-trapping
One filter is pro-flow.
Both are high quality. Use is dependent on need.
They use to say it was 50% @ 20u ... which is farther down on the efficiency curve. Obviously 99% @ 35u sounds better to the unknowing.
Ultra flows very well ... and one filters way more efficiently. Again, PD oil pumps make "flow over filtration" a completely moot point. Now if you mounted oil filters on your kitchen sink faucet or refrigerator water circuit it might be a different story when talking about "flow over filtration".
This is my Fram Ultra (Venza) with a 10k mi OCI ( with a 5K OC)
[Linked Image]
Looks like I happened to use your PC data a while back when I made up this chart. Your data is Filter D (yellow line).
that's really quite good
Thanks. I am encouraged to do another Blackstone particle tests with only 5000 mi on the OC.
Originally Posted by PimTac
Trico makes good filters.
I guess good is relative. You would have to compare it to Fram Ultra for this to have meaning. When I found out the difference between the Ultra andt he Mobil 1 filter I mmediately removed the Mobil 1
On that note, has anybody here had any experience with Donaldson filters, but in an automotive gasoline engine application, not a diesel or off road application?
I did find that they do make a filter for my engine #550162, but was curious if they use the same media that is touted to be excellent in their bigger filter apps.
Trico is the new owner of FRAM
Why is that?
Originally Posted by Dad2leia
On that note, has anybody here had any experience with Donaldson filters, but in an automotive gasoline engine application, not a diesel or off road application? I did find that they do make a filter for my engine #550162, but was curious if they use the same media that is touted to be excellent in their bigger filter apps.
There's a thread around here that shows one (a standard ford FL-1A size/type) cut open - and it's exactly the same as Amsoil or Fleetguard
Yep, I think the news hasn't hit everyone yet.
https://photobucket.com/gallery/user/bigodave/media/bWVkaWFJZDo2Njg2MTk2OQ==/?ref=
https://bobistheoilguy.com/forums/posts/344447/
https://bobistheoilguy.com/forums/ubbthreads.php/topics/1243687/2
https://bobistheoilguy.com/forums/ubbthreads.php/topics/315578/baldwin-b2-hpg-donaldson-p169071
https://bobistheoilguy.com/forums/threads/where-to-buy-a-donaldson-p169071.113600/
https://www.bobistheoilguy.com/foru...lo-and-goodbye-to-my-old-job#Post5050994
