Originally Posted By: Nyogtha
Just picking your brain Car51 - why the NG 7060 instead of the 7899?
The NG 7899 / Wix 57899 / CQ Blue 84899 is what's spec'd for my 2012 5.7L Hemi Ram.
I put a bunch of the CQ 84899 in my stash. That part number was discontinued when CQ switched to Purolator so when you find them they're either WIX or Frampion vonstruction - no Putolator! Cheaper than NG 7899 too, plus you can use AAP discount codes.
Good question, he gets this filter from local NAPA store; I guess it works good so why not
Fair enough. Just that the
NG 7060 is a reduced size filter (3" diameter, 3" tall) instead of the
NG 7899 (3.67" diameter, 3.74" tall) for his model year, like maybe a jobber would have on hand to avoid stocking two filter sizes. The 7060 is the size usually used on later models with electric power steering, due to less clearance for getting the filter in & out on those models. Just FYI y'all could be using a full size 7899 filter instead.
Here the 7060 & 7899 are both $7.29 at NAPA, the
Wix 57899 is $6.99 at O'Reilly, and the
CQ Blue 84899 is $6.49 at AAP while they last. With a 30% off code, the CQ Blue 84899 is $4.54. So thmere's more filter available for his application at equal or less cost FYI.
Well, he found he can get a WIX 7899 for $4 at mom and pop parts place in his town. Said he may get one of those next time. Yeah, newer RAM's use the PH 48 filters I see
