AstroTurf
Originally Posted By: kr_bitog
Originally Posted By: AstroTurf
PS The Michelin website even allows for increased pressure (for this tire) Based on speed and load.
Look all the way down at the bottom... In the Fine Print. LOLz
http://www.michelinman.com/tire-selector/category/light-truck/ltx-m-s/tire-details/
Here below is the fine print,
they allow increase for higher speed but not for higher loading and not beyond pressure marked on tyre sidewall.
Inflation pressure increase must not exceed the maximumpressure branded on the tire sidewall. Whena customer requests a replacement tire with a lower speed rating than the original equipment tire, you must clearly communicate to him or her that the handlingofthe vehicle may be different, and that its maximum speed capability is limited to that of the lowest speed-rated tire on the vehicle. Exceeding the lawfulspeed limit is neither recommended nor endorsed.
For high-speed driving, additional inflation pressureand possibly reduced tire loading and/or upsizing is required. In the absence of specific recommendations by the vehicle manufacturer, usethe following guidelines based on those in the European Tyre and Rim Technical Organization Standards Manual.
For speeds over 160km/h (100 mph), load and inflation must be adjusted according to the table below.
S-Speed Rated Sizes:
Maximum Speed (mph) 100 106 112
Inflation Increase (psi) 0.0 1.0 2.0
Load Capacity(% of max.) 100 100 100
How can they allow for a psi increase without exceeding the sidewall psi?
Strange indeed, Jim
Strange indeed, Jim
