I've spent way, way, way, too much time (no, seriously, way too much!) researching this to not share it and hopefully save others the frustration, there's no shortage of bad info out there, including annoyingly from the OEM's themselves. This is primarily focused on brake part lubrication but does include some odds and ends and is far from complete or definitive, if you can believe that!
Manufacturer is listed first if known / Followed by other sources of the same product (Part Number) - Color of the product (NOT the packaging), Description with known info, absence of info does not indicate that the product lacks that quality
Silicone Oil Based Greases:
Silicone Oil Based Compounds ("Dielectric Grease"):
Glycol Based Greases:
Pastes:
Unknown:
Note: Molykote brand products have been referred to as Corning, Dow, Dow Corning, DC, DuPont, etc, Molykote is used here throughout for consistency
Discussion:
Rubber Grease as defined by the Japanese auto makers seems to refer to products meeting JIS-K-2228 which "specifies non-petroleum base rubber lubricant (hereafter referred to as rubber lubricant), to be applied to the components of automobile brakes which use non-petroleum base brake fluids for transmission of working pressure". It appears to be a performance based standard for ensuring products do not damage rubber parts, and does not seem to exclude silicone based products.
Petroleum based products are NOT recommend for brake caliper / drum lubrication, petroleum fouls brake linings and can lead to grabbing or loss of braking power, it can also damage rubber parts and seals.
Applications:
Brake Pad Backing Plates / Shims, Retainers and Clips, Caliper Brackets:
Pastes, such as CU-7439 as spec'd by Subaru, Nissan, and others, as well as Toyota "Disc brake grease" (08887-80609), have generally fallen out of favor to dedicated Anti-Squeal greases such as AS-880N. Compare Toyota T-SB-0136-11, where "Disc Brake Grease" (08887-80609) is applied to the shims and pad ears, versus T-SB-0248-12, where an updated pad kit has AS-880N as Disc Brake Shim Grease (08887-80409) applied to the shims only.
Nissan and Subaru call for AS-880N as well, Subarau recently released TSB 06-68-19 calling for AS-880N to be applied on supports, clips, and ears.
Interestingly Honda still maintains a solid preference for Molykote M-77, why? Beats me.
Caliper Slide Pins and Boots:
Toyota has consistently called for "Lithium Soap Base Glycol Grease", aka Toyota Rubber Grease (08887-01206), on caliper slide pins, see for example T-TT-0132-11 and TS-TR-0075-D. You may see Russian sources saying to use Toyota Brake Caliper Grease (08887-80609), but a CAREFUL reading of this post makes clear that it was only recommended to do so in one specific TSB which appears to have involved Bosch supplied parts. The post does note that many have complained about Toyota Rubber Grease drying out too easily, and for that reason a silicone based grease is worth considering.
Subaru, like Toyota, has consistently specified their preferred rubber grease (Niglube RX-2) only.
Honda, on the other hand, dropped the use of rubber grease (08733-B020E) sometime around 1999 when it was not listed in their Recommend Materials TSB 99-030 Version 1 (Attached, can't find a good link ATM), in its place Honda Caliper Grease (08C30-B0224M) was listed for the task with the description "High-temperature, silicone-based grease used to lubricate caliper slide pins".
Drum Brakes:
Shoe Ends and Sliding Points/Surfaces:
The most common recommendation I see online is for Copper Anti-Sieze here, and while at one point at least both Molykote and Subaru called for it, I don't think it's a good choice for two reasons; the petroleum base oils can foul friction lining if the product is applied incorrectly or the oils drop out. And drum brakes, especially rear drums, and undoubtedly parking brakes simply don't get hot enough to necessitate copper over other better lubricating solid particles. A high-temp silicone based grease such as Molykote 44MA seems to be what the OEMs are moving towards here.
Adjuster and Springs:
You can find just about everything specified for this depending on where you look, trying to figure out what to use on drum brakes is actually what started this spiral into madness. Personally I'll be going with the aforementioned high-temp silicone product as that seems to be the most common type of product called for lately.
All trademarks are owned by their owners, accuracy not guaranteed, Your Mileage May Vary, not liable for misuse, use at your own risk, I think you get the idea...
Questions? Comments? Corrections?
- Honda Silicone Grease (08C30-B0234M) - Supersedes Honda Caliper Grease (08C30-B0224M), may be a compound, very expensive ($50!), not to be confused with Shin-Etsu G-30M
- Molykote 44MA / Subaru (26648FJ000) - Black, Lithium soap thickened, Molybdenum disulfide (MoS2) solids, I have not found anywhere to obtain this in reasonable quantities
- Molykote AS-880N / Subaru (K0777YA010) / Toyota Disc Brake Grease II (08887-02307) / Toyota Disc Brake Shim Grease 5g packet (08887-80409) - Black, Silica thickened, with Graphite, Mica, and Magnesium Oxide, used to lubricate clips and shims as an Anti-Squeal
- Toyota [Disc] Brake [Caliper] Grease (08887-80609) - White, Silica thickened? PTFE solids, possibly a Molykote product
- Shin-Etsu G-3W-0-M / G-30M - Grayish White, Honda "Shin-Etsu Grease" (08798-9013), Subaru (004404002), swells Silicone rubber, excellent for Honda door seals, low temperature, I would NOT use it on brake parts
- 3M 08946 - Translucent White, NLGI #3, "100% silicone lubricant"
- Fuchs CHEMPLEX 839 / ACDelco 10-4019 / GM (88862181 / 88862182) / Raybestos DBL-2T / DBL-3 - Translucent? White, NLGI #2, PTFE thickened, metal particle solid lubricants
- Ford / Motorcraft D7AZ-19A331-A / WA-10 / XG-3-A / Mazda 0000-77-XG3A - Translucent White, meeting Ford spec ESE-M1C171-A
- Molykote 111 - Translucent White to light grey, Slightly lower temp range than KS-62M
- NyoGel 783D / Nissan (999MP-AB002) - White, Very thick NLGI #4, TDS, SDS
- Shin-Etsu KS-62M - Translucent White, Heat Resistant, supplied in packets with kits for use on caliper seals
- Niglube RM / Mitsubishi (MZ101616EX) - Orange, NLGI #2, Sodium-complex soap, High-temp SDS
- Toyota Rubber Grease (08887-01206) - Red, Manufactured by Cosmo Oil Lubricants, MSDS
Pastes:
- Molykote M-77 / Honda (08798-9010, possibly 43231-SB0-315 5 packet) / Nissan (44003-7S000) - Black-gray, Molybdenum disulfide solids base, Lithium soap thickened silicone carrier oil, noted by Honda to 'polish more than it lubricates'
- Molykote Cu-7439 / POLYSI PST-7439 / Nissan (44003-14C10PP) - Copper, Lithium soap thickened PETROLEUM oil base, Copper solids, high-temp copper anti-sieze
Unknown:
- Niglube RX-2 / Subaru Rubber Grease (000041000) - Orange-red, Lithium soap thickened, unknown non-petroleum synthetic base oil, low temp range (-30 to 130c)
- Sil-Glyde - Both Sil-Glyde Lubricating Compound and Sil-Glyde Brake Lubricant currently share an SDS, the only component listed is Castor oil 30-60% by weight
Discussion:
Applications:
Drum Brakes:
