My Quest for Good Cheap Oil
But he has been consistently skeptical about long OCI's even if Amsoil etc.
You keep disagreeing with me for some reason, and I don't know why. I'm not arguing with you. Yes, he has always said that. He re-iterated his position on that in this most recent video. He recommends 5000 mi or 6 month intervals. He also is mainly trying to convince your average American to get their oil changed with bulk oil at their local oil change place. He is talking to the lowest common denominator. Your average person who knows very little about car maintenance. He isn't making videos for BITOG members.
I have a quick question, please save the forum from yet another thread. Long OCI oils have extra dispersents, so they pick up stuff and some of that stuff may be too small for the filter and they will circulate throughout the engine. Isn't that bad? Wouldn't it be better to have short OCI cleaner oil instead?
This isn't a quick question. Many, many threads and countless posts have been made here on OCIs. I'd recommend searching and reading. You seem to think there is an easy answer to this question, and there isn't. If there is still something you don't understand, I'd recommend making a new thread with your question so we can keep this one on topic.
Give those all a read and see if your question is answered.
I am not disagreeing. My first comment was to support your comment that I also gave a like. I don't know what is going on in your mind. My second comment was about saving one's time and energy spent on UOA and just doing a safe OCI and I spent so much on used oil analysis and VOA's and they didn't help much, all oils look very similar on UOA. Again, supporting and agreeing with your comment.
Years ago I was on a quest for the best oil I could get. That led to a lot of wasted money.
In recent years I'm on a quest for good cheap oil. From among low cost options, which are good performers, low cost, and easily locally available from Walmart, NAPA, or Oreilly because those are the oil sellers near my home.
Here's my finalists. Please tell me which you think is better and why (for 3 high mileage vehicles that don't leak oil, though one does burn oil).
NAPA High Mileage Full Syn
Quaker State High Mileage Full Syn
NAPA Full Syn
Quaker State Ultimate Protection Full Syn
I'm also open to other good oils suggestions if they're low cost at Walmart, NAPA, or Oreilly.
I've been on the same quest after wasting so much money over the years on expensive oil and filters at 4,000 mile oil change intervals.
I don't even own those cars anymore. What a fool I was.
Now I just use SuperTech High Mileage Full Synthetic 5w30 and Super Tech oil filters (DIY oil change using ramps). No reason to spend more for no benefit.
I've been on the same quest after wasting so much money years ago on expensive oil and filters.
Now I just use SuperTech High Mileage Full Synthetic 5w30 and Super Tech oil filters. No reason to spend more for no benefit.
That works until it doesn't.
I think it is very engine- and conditions-dependent. It's difficult to make a blanket statement that works for everyone.
If you've got a known fuel dilutor, an engine hard on oil (Subaru comes to mind), or use it consistently in severe conditions then it's probably worth it to spend the money on a more expensive oil. If you have an engine easy on oil and drive it on the highway with cruise control 99% of the time, then you can probably get by with Supertech. The guy who put 1 million miles on two different Tundras did it with 0W-20 bulk oil. But you can't recommend that to everyone. If you are driving a late model Subaru, you're going to burn oil, for example.
Supertech isn't that much cheaper than Quaker State Euro, for example. The difference in quality is worth it to many. But you are free to choose.
A friend's Jeep went 410K using Supertech oil, oil and air filters. Not any Supetech premium stuff either. Just the cheapest versions of Supertech products.
See this post about a wear test video of 4 oils that includes Supertech.
Post in thread 'My Quest for Good Cheap Oil' https://bobistheoilguy.com/forums/threads/my-quest-for-good-cheap-oil.398231/post-7320580
But which Jeep? The 4.0L? That would have done it on peanut oil. The 3.8 was also pretty robust. The 3.6 is problematic.
Super Tech might even be better than the name brands.
My thinking is:
Name brand big companies are under pressure from shareholders to cut costs, increase profits, which leads them to cheapening their products. That's why you see First Brands/Fram cheapening their oil filters. The same could be happening with big oil companies.
Warren distribution on the other hand has a growing following with Walmart, Costco, Amazon Basics customers.
Warren has a $0 marketing budget which allows them to lower the price of the oil.
It's very unlikely they would cheapen the oil and risk losing a contract from Walmart.
Exactly. It’s a testament to the engine not the oil. I’ve personally run 4.0’s and Buick 3800’s over 300k on conventional Chevron Supreme back in the day.
I respect your opinion.
For what it's worth, my three 2006-2007 Honda Odyssey EX-L's all have the J35 engine with their 1st generation VCM enabled.
Some SME mechanics on BITOG called this engine the hardest on the oil of any engine they've ever worked on. The engine temps on the cylinder heads reach extremely high temps and cook the oil due to the first generation variable cylinder management and a poorly designed PCV.
I've been using SuperTech High Mileage Full Synthetic 5w30 at 5,000 mile / 6 month (whichever comes first) OCI in these engines for 3+ years.
No issues to report.
I wouldn't hesitate to use Super Tech even in a Ford F150 with an Eco-boost engine with it's high temp twin turbo and very long timing chains which need constant lubrication.
In my case PUP and Mopar filter cost $35 if I downgrade from HPL and Red Line. If I go super tech oil and filter, that would probably be $25. $10 will not make me rich. In 6 months people spend more money on car wash than they spend on oil
Yeah it's not a problem until it is! Fouled oil control rings take time to show up. I respect your opinion as well, and I'm not trying to convince you to change. You've been here a while and read a lot and seen a lot of reports. I have come to a different conclusion based on the information available to me from reading reports here.
Chevron is a good oil or good enough. Yes the J4L & B3800 are great, but I think the oil has to be reasonably good (highly adequate) to go 300-400K miles even in those engines.
That said, I stopped using Chevron oil when I discovered that Shell is (IMO) better. Likewise I switched from Chevron gas to Shell gas for same reason.
  • Like
Reactions: GW.
Exactly this. You get a lot more with a small increase in spending.
Did you watch Lakespeed's video that I posted? He said the NAPA Full Synthetic has more of a superior type of moly in it that explains the lower wear in his used oil analysis tests. However, you might have also made a valid point about suspension of particles. I don't know.
I'm not a chemist nor professional oil expert. So I'm not qualified to doubt Lakespeed. I'm also not qualified to doubt you.
One of my great uncles was a certified gas and diesel mechanic, and a welder. He worked for big oil companies in AK and mechanic shops in OR. He was also the foreman in charge of diesel mechanics, maintenance crews and fleets. He always used NAPA oil and filter in his gas pickup truck. I think he knew what he was doing.
So I think NAPA oil is at least good enough. I think it's plausible that it may be better than good enough and actually quite good. I know NAPA Gold filters are top notch.
I used to buy NAPA full synthetic back when it would go on sale 18.99 for 5 Qt jugs. It’s excellent oil and as mentioned formulated by valvoline. I’d buy 5 to 6 jugs at a time. I still do buy it but I think the days of 18.99 or long gone. Used it in my Nissans Toyotas scion with the Mazda engine dad’s Kia vehicles. No complaints here.
SuperTech High Mileage Full Synthetic 5w30 is $18.64 for a 5 quart jug + 3.84 for the Super Tech oil filter = $22.48 + tax.
DIY oil change using ramps means $0 in labor. Regarding car washes, I just use the hose LOL and my well water is free.
