- Joined
- Feb 27, 2019
- Messages
- 631
For example, Castrol Edge and Castrol Edge EP. Let's say one is recommended for 5K while the other can go 10K.
If you change both at 5K, is the wear, breakdown, etc. the same? Or does the standard oil protect better than the extended version until that point?
Basically, is the performance of the oil the exact same except the extended one can be run longer?
