kevm14
Thread starter
According to this,quote:
Originally posted by ebaker:
Does the friction modifier increase the fluid's coefficient of friction or decrease it?
it decreases it. So apparently I shouldn't be using ARX to bring back my pinion seal. What else should I do? I don't feel like R&Ring the carrier/gears just to do a stupid seal. Or should I just live with the leak and top it off on a regular basis?quote:
when you change the fluid, leave out the friction modifier. this will help the limited slip function come back. if it comes back strong and you start to get popping while turning, then you can go back to add some modifier.
