Hi,
CIRHS - You said this:
"What is the oil film strength of say xw20 compared to xw40 or xw30 oil and has anyone done a UOA to campare engine wear with thin oils?"
It is wise searching on here as this matter has been long discussed over several years
The ACEA Quality rating system clearly spells this out and the API are now playing catchup along similar lines
AEHAAS - Less viscous lubricants have long demonstated an ability to stay in grade and the 20W-20 lubricants of the past (even 50 years ago) had a great reputation in this regard. The latest lubricants are indeed great products but it is always a case of "horses for courses"
You said this:
"Also, when you talk about viscosity you must at the same time talk about oil temperatures. A 20 grade oil at 180 F has about the same viscosity as a 30 grade at 200 F and about the same viscosity of a 40 grade oil at 220 F and so on."
This is true and in many Porsche engines an SAE50 lubricant (say 15W-50) will spend much of its life at a bulk temperature of around 90C and at a viscosity nearing SAE60! This does nothing for the optimal operating efficiency of an engine that should have a SAE40 lubricant (say 0W-40)
That is one side of the equation - the other side is the lubricant's operating and "return to bulk" temperatures. IMHE this raises the importance of the HTHS viscosity. The lubricant spends much of its time a long way from the bulk temperature and I have measured many engines where this is way beyond 150C and in those areas where external temperatures cannot be taken, much much hotter!
Insufficient HTHS viscosity will indeed cause wear and this will not be reflected via UOAs - even the ACEA Test parameters indicate this
Using the less viscous of those lubricants Approved and Listed by the engine manufacturer will provide the best likelihood of optimal operating efficiency and the enhanced fuel economy and performance that goes with it
As an example most Mercedes Benz engine families allow all year round (30C) (86F) use of from 0W-30 to 5W-50 synthetic lubricants from their List of Approved lubricants
Some engines do need to have a HTHS viscosity at at least the minimum number prescribed by the engine's manufacturer. IMHO it is unwise to go under this for any length of time and to expect the ultimate in long term durability!
You said this too:
"If you race your BMW with sump temperatures of 290 F then it would be safe to use a 20 grade oil if the sump was 180 F."
I have some difficulty with this......................................? You do not mention the HTHS viscosity and the lubricant's ability to maintain it
You said this:
You said this too:
