Originally Posted By: oliverr871
After some more thinking, I will just get a non-sludged low mileage engine. Thanks guys.
Are you able to tell if the noise is in the valve train or is it from below? Do you plan to pull the motor yourself? If so, when you pull it, take the oil pan off and take a look at the bearings. It's really easy to check the clearance using plastigage. It would be interesting to find out what kind of shape the bearings are in. I still think that unless the engine has been seriously starved of oil, it might not take much to get it back in shape, although I would add lifters to the list of parts, since they are probably contaminated with dirty oil that bypassed the filter.
