Originally Posted By: aquariuscsm
This thread reminds me of those BMW sludge threads where they pull the cover off the 80k or so engine,that had those 15k synth oci`s,and the sludge is so thick you can`t even see the camshaft. When I used M1 in my gf`s Olds 88,the oil would drain out looking like tar after 3000 miles. I just couldn`t imagine being too cheap to change the oil in shorter intervals on some uber-expensive car.
I do 10-12k oil change intervals on my 740, and there is no sludge, as you can see from my pictures. It has 130k...4k less than my 323i. Using the right synthetic oil (BMW LongLife approved oils) with the car and changing it at the intervals the car suggests definitely works.
Dino oil, or not, obvious lack of changing can definitely contribute to sludge.
I checked the filter yesterday, and there are sludge elements in between the pleats. It only has been less than 3k since the last oil change, so I will wait until it catches more then change it with a new filter and put some MMO.
Before I had done the oil change, assuming that the oil change interval meter is correct, it said 5k until oil service. The filter had heavy crudding, and it still ran great! haha
