Basically I have tried a lot of different brake pads. The more aggressive, the more bite a pad has the less life and the more stress it puts on the rotors. The very best sport pads are semi-metallic variety with a lot of bite and stopping power. However, I never get those pads to truly last and they most always warp the rotors. On the other end of the brake pad spectrum is the ceramics which last a long time. Akebono is the king of ceramic pads and most vehicles from the factory come with Akebono ceramic pads. The Chevrolet Suburban, Toyota Camry and many others come from the factory with Akebono pads. The Akebonos last a long time and dont warp the rotors...however they feel like sponges and overall braking feel/power is not desirable.
Wagner came out with a pad called OEX which I have determined to be the best pad for my personal preference. They last a lot longer than semi-metallic pads, but have a bit more bite than Akebono OEM ceramics. They are basically a compromise pad.
If your front brake pads wear out first than you will want to put semi-metallic on the rear and Wagner OEX on the front. The proportioning system on a vehicle of that type uses the front brakes most and thus to get more power out of the rear brakes you go more aggressive with the pad. However, if your rear brake pads tend to wear out first than you want to put Akebono standard ceramic on the back and Wagner OEX on the front. The proportioning system on that type of vehicle equalizes braking power front/rear and thus tends to wear out the back pads first. Thus its more appropriate to put ceramics on the back for a satisfactory rear pad life.
