Originally Posted by Triple_Se7en
My Colorado engine was built for 5w30. I had six quarts of six year-old NAPA 0w20 hidden under the steps of the basement and when we changed flooring, I uncovered that box.
So I tried it in the Colorado as an experiment. After 1k in accumulted miles, my computer in the 3.5 engine went haywire and needed a replacement. It took five weeks to get the new computer from Florida, over 1300 miles away. Shipping and storage during COVID was to blame for the long delay.
I was at the mechanic's business garage when the new computer was downloaded and installed. Now was the time to start the engine after 5-1/2 weeks of shutdown. Upon startup, the loudest clatter erupted from the engine, similar to an engine without oil. Lasted almost five seconds. Some tweaking was done to the computer readings and truck was placed outdoors.
Wife arrived with the checkbook three hours later to pay the bill. I started the engine again and another five seconds of loud clatter occurred. So my question here is oil film strength. Is it possible to rate today's 0w20 SN Plus (soon SP) oils on film strength? Would I be wrong in saying NAPA 0w20 Synthetic has lousy film strength? That Colorado 3.5 engine is not of the old-school flat-tappet design, that it's predecessor 1999 Chevy S10 with 4.3 engine had? The 3.5 is more of a reflection of today's engine designs.
BTW..... my cold engine starts have returned to normal, just by removing the 0w20 - removing the almost new oil filter - letting the filter drain empty and reinstalling it - plus installing new oil ....Pennzoil Gold Synthetic Blend 5w30.
Have we ever discussed film strength before - here at BITOG? Wouldn't film strength tests like what I uncovered, be a good indicator on how well some of these thin 0w20s protect our engine, over the course of a long-term shutdown of 5-1/2 weeks?
Or should we expect the same engine clatter, from all 0w20 synthetic oils, after a long-term shutdown?
Such cold-start valvetrain clatters have often been attributed to defective variable-valve-timing actuators. If using an oil that runs a lot thicker when cold—a normally undesirable thing—corrects the problem, it's neither a good fix nor a permanent fix. Chances are that the same problem will reoccur in warmer- or colder-weather cold starts.
All oils, even a SAE 0W-8 oil, have extremely thick oil films when they are cold. Therefore, oil-film strength is a nonissue in a cold engine.
