Multiple DTCs on Camaro v6 2011; need help please
GON
$175 Site Donor 2026
White Sands, NM
Pastor’s daughter Camaro has been at at shop, but still reported to have significant running issues.
Shop states the replaced the spark plugs, repaired a coil in cylinder 1, oil change, and coolant flush to solve the engine idling rouch and dying while in gear stopped at a stoplight. Going to post the dtc, if anyone has any thoughts on what’s going on, kindly ask to post those thoughts..
Consider my advice "amateur hour", but if a car has that many varied codes, I'd be looking at computer and wiring harness issues. AZjeff is onto something. Water, rodents, body damage, something ripped out under the dash, etc.
That's way too many "codes" to even be helpful at armchair, internet diagnostics.
If it's still at the shop, pay the bill and go somewhere else. I do hope the plan isn't to take "diagnoses" from here and tell the shop what to do ! 😳
You might glimpse at freeze frame on some of the heavy hitters, but yeah man -- wipe the slate clean and note which reappear first. Right now it's just analysis paralysis
The first code is an immobilizer code, then a ECU code, then a TCU code, then a bunch of system codes, sensor codes and misfire. I am surprised it runs.
A single sensor or whatever does not throw this many codes. I also suspect wiring / ground / low battery / ECU.
Can you at least edit the pictures and rotate them so there readable.
This idiot's two cents....all I see are two DTC's: Intermittent misfire and an intake camshaft position sensor issue, that also appears to be intermittent. Might be the two are related?
As others have said, clear the codes and see what comes back. Then attack the code that seems to point to the main problem first and then go from there. Fixing one code may fix others. Some of those codes could be from a low battery or unhooking sensors and components with the key on.
