My generator with a Brigs OHV engine recommends 10W - 30 for temps under 30f, while above 30 deg, it suggests 30 W. Well I never know what temperature it will be when I need to run the back-up generator. It may be in the middle of a winter ice storm, or a warm spring tornado season. Which oil is is most likely to cause the least wear if used in the wrong ambiant temperature range? I'm not going to leave the crancase empty an fill with the proper lubricant at the time of use.
