edyvw
$50 site donor 2026
Originally Posted by supton
What's so hard about an ice scraper and cracking a window? That is what I do, unless if there was a storm and I have an inch of ice; in that case yeah I'll let it idle so as to soften the ice. But for frost? scrape and motor off.
I leave the heat off until I see the temp gauge move. Is it hurting anything to turn the heat on full blast right after getting in? Nope. Technically the heater core acts like a mini-radiator (same principle) only the real radiator has a thermostat that won't open when the coolant is below a temperature around boiling--but the heater core gets coolant always, so turning on the heater fan is going to slow down engine heating up. Does it really matter? I'm not sure--the engine will warm up faster with it off, but once on, it's still drawing heat away, so I'm not sure it matters... me, I just don't want cold air blowing on me, so I wait until I know it'll be warm air blowing on me.
My truck drops mpg badly in winter. I drove it year round once and could hit 20 mpg, 21 even, in summer. Snow tires and winter dropped it to 16 mpg. Although now that I drive it little it seems to get 16 year round... my other cars will drop in cold weather but it seems like, if it's above 20F I don't have much of a change. But for me, a short trip is 15 minutes, most trips are much longer--once up to temp, winter losses are not massive.
IIRC winter blend gas often has a bit less Btu's per gallon, so there's something like up to 5% there (but it varies with the blend).
Dramatically! Also depends on the vehicle, but it will slow down arm up process.
