I have been seeing advice and videos about adding zerk grease fittings to blade spindles. Seems silly to me since the bearings used are closed bearings. Even if you add the grease you would have to fill the entire void and can't be sure the top bearing will get any additional lubrication while the bottom bearing will probably leak grease out the bottom. Some examples remove the top seal on the bottom bearing and the lower seal on the top bearing. Anybody actually do this and did it prove effective? Bearings are cheap. My BigDog C142 is 14 years old and still running on the original spindle bearings. Maybe I have just been lucky but if I was going to go to this much trouble I would just change the bearings and be done with it.
