Hi guys, i am using this oil, Motul Sport Ester 5W-50, and i would like to ask you, is anyone else using this oil? It's a new release and i can't find much info. I am asking just in case someone else has sent a sample for examination, and has some data to share. I have a sample ready to ship to Blackstone already.
Btw, i am using this oil in my 02 MINI Cooper, normally aspirated, with 4032 forged pistons, 11.7 compression ratio etc, manufacturer specifies 0W-30, 5W-30, 0W-40 and 5W-40 oil, but i decided to use this because it looks promising in the spec sheet and thought this would be much better for high rpm use. It did improve my oil pressure about 3-4psi over the previous Elf 5W-40 i was using, just to mention.
It's specs are :
cSt@40C : 107.1
cSt@100C : 17.9
HTHS : 4.5
VI : 186
TBN : 8.4
Flash point : 244C/471F
I live in Greece so the climate is relatively hot, the lowest startup temp is around 5C, and this only a few days round the year.
Any opinions or data to share welcome
It's specs are :
cSt@40C : 107.1
cSt@100C : 17.9
HTHS : 4.5
VI : 186
TBN : 8.4
![smile.gif](https://bobistheoilguy.com/forums/graemlins/smile.gif)
