Motul LL-01FE oils
Vancouver
I noticed the data sheet on these two oils are identical, aside from a tiny difference in KV40 which could easily be a typo. Are they really bottling the same oil in two different bottles? The first oil doesn't say LL-01FE on the data sheet, but it does on the bottle. It has a couple other approvals as well.
Nope. First one is 05/23 and second is 12/22
Well then I would consider them the same. Difference in KV are probably within the margin of error.
"Precision — Precision of the viscometer meets D445, which specifies repeatability of less than 0.11 percent on base oils to 0.26 percent on formulated oils and reproducibilities at 40°C and 100°C of 0.65 and 0.76 percent respectively."
