this was my first ever oil analysis and i was very nervous opening the email i received, just like getting uni results
Motul 4100 15/50 Turbosynthetic (part synthtic ranks behind the 300v, 8100 and the 6100 )
My 1999 Subaru Wrx Sti has had new bearings put in about 8000kms ago.
This oil is 1000kms old of which 100kms in 37deg celcius heat of track work.
Metals
Al 2
Cu 1
Cr 1
Fe 2
Pb 3
Sn 1
Contaminates/Additives
Si: 6
Na: less than 1
Physical tests
Water % by crackle: less than 0.05
Viscosity ~ cst, 40deg C: 123
PQ index: 26
Fuel : Pass
what does everyone think. considering this oil only went 1000kms?
does that mean if i was to go 5000kms i could extrapolate the "wear" figures by a factor of 5?
has the viscosity held up?
also, do you think i need to change the oil?
thanks for any input
[ January 16, 2004, 05:32 AM: Message edited by: StiMan ]
Metals
Al 2
Cu 1
Cr 1
Fe 2
Pb 3
Sn 1
Si: 6
Na: less than 1
Physical tests
PQ index: 26
Fuel : Pass
