Originally Posted By: SSerian
Subaru Factory Fill
6008 miles
Subaru WRX STi
One long road trip to 100 Acre Wood Rally that involved very dusty roads. No makeup oil added. I did swap to a Perrin foam filter for the last 1000 miles of this OCI. Curious to see how well it does. Blackstone makes a note in the drop in Silicon from the original OCI to this change but that it is too early to see effectiveness.
Blackstone Notes:
We're having a hard time getting a good look at air filtration effectiveness for a couple of reasons.
Dirt looks the same as harmless sealers in a spectral exam, and some of the silicon is left from initial
wear-in. Red Line also uses some silicon in their oil as additive, typically around 10 ppm. We're inclined to
say the air filter is doing a good job since silicon came down a lot from last time, but there is a little bit of
uncertainty in saying that for the reasons outlined above. Copper and iron are shaping up nicely, and the
TBN was strong. 6,000 miles on the oil should work well.
Code:
MI on Oil 6008 3864
MI on Unit
Sample Date 05/26/2016 02/26/16
Make Up Oil Added 0 0
Oil Type RedLine 5w-30 Subaru Factory Fill
Unit Avgs
ALUMINUM 1 6 4
CHROMIUM 1 1 1
IRON 15 27 21
COPPER 54 70 62
LEAD 0 0 0
TIN 1 1 1
MOLYBDENUM 605 1061 833
NICKEL 0 0 0
MANGANESE 1 4 3
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 3 4 4
BORON 48 165 107
SILICON 27 123 75
SODIUM 13 6 10
CALCIUM 2435 2034 2235
MAGNESIUM 8 21 15
PHOSPHORUS 963 895 929
ZINC 1129 1006 1006
BARIUM 1 4 4
SUS Viscosity @ 210°F 59.0 51.6
cSt Viscosity @ 100°C 9.92 7.75
Flashpoint in °F 375 385
Fuel %
Antifreeze % 0.0 0.00
Water % 0.0 0.0
Insolubles 0.2 0.2
TBN 3.0 N/A
Subaru Factory Fill
6008 miles
Subaru WRX STi
Blackstone Notes:
Code:
MI on Oil 6008 3864
MI on Unit
Unit Avgs
ALUMINUM 1 6 4
CHROMIUM 1 1 1
IRON 15 27 21
COPPER 54 70 62
LEAD 0 0 0
TIN 1 1 1
NICKEL 0 0 0
MANGANESE 1 4 3
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 3 4 4
BORON 48 165 107
SILICON 27 123 75
SODIUM 13 6 10
MAGNESIUM 8 21 15
ZINC 1129 1006 1006
BARIUM 1 4 4
Fuel %
Water % 0.0 0.0
Insolubles 0.2 0.2
TBN 3.0 N/A
