Mostly highway and suburban roads, with some stop-and-go. Once it is warm I am not afraid of the gas pedal.
Oil consumption was about 1 qt/1200 miles, which is a big improvement from the previous OCIs in which part of my PCV system was gunked up.
On the day I took this sample, I also replaced my VANOS unit. It was well worn and apparently not advancing cam timing the way it should have, so the engine was running somewhat poorly until 4,000 RPM. Keep that in mind when you view the results.
Previous oils in order are:
Motul 300V 5w-40
Motul 8100 X-Cess 5w-40
Motul 8100 X-Max 5w-30
Driving style was about the same for all three previous OCIs.
Motul 300V 5w-40
