This is my second run on the low-ash version of RLI's 15w-40 heavy duty engine oil. I ran it longer this time and results are still good. By the end of the run, my car's OLM was at the end of the green zone (after which there is yellow and then red), which once again seems to be right on target given the oil's condition. I think I've found the oil I'll be sticking with for the rest of my time with this car.
I am completely baffled by the drop in fuel dilution. I did replace the spark plugs about 900 miles before drawing the sample, so maybe that did it. The car is still throwing ghost codes (i.e. no check-engine light) for a resistor in the ignition system and an O2 sensor, so... who knows.
The silver blip is probably from anti-seize from my friend's compression tester, which we used within 200 miles of pulling the sample.
According to RLI, sodium is NOT an additive in this oil and should not show up on the UOA. I don't know where it could be coming from other than coolant entering the combustion chamber in such a way that the water and glycol are burned off.
Summary of the OCI:
- Warm-ups have been less cautious than on previous OCIs. Once warm, the car is driven... hard. Let's just leave it at that.
- Mostly suburban and highway.
- Oil consumption accelerated to near 1 qt/1000 mi.
- Overall, the car runs well, but it's still a bit jerky on throttle transitions.
Report below. Middle column is the current sample; last column is the previous one.
Links to previous UOAs in order from most to least recent. Please note that the numbers from this UOA are NOT comparable with those from different labs:
RLI BioSynXtra 15w-40 HD Low Ash (first run)
RLI BioSynXtra 5w-40 HD (third run)
RLI BioSynXtra 5w-40 HD (first run)
RLI BioSyn SHP 0w-30
Motul 300V 5w-40 #2
Motul 300V 5w-40 #1
Motul 8100 X-Cess 5w-40
Summary of the OCI:
Motul 300V 5w-40 #2
Motul 300V 5w-40 #1
