111 is not a high pressure application grease. It's great for things like O-rings, and blocking water entry. I would not use it as general purpose grease for a motorcycle.I haven't used it in this specific application but I would try a professional grade silicone grease like Dow Corning 111. It's what I've had the most experience with, used to be able to get it for a good price. Waterproof and lasts forever. Really.
Exactly. I used it mostly where corrosion or plastic / rubber components were of concern. Great for ignition wires, boots, connectors, electrical plugs. I'm not sure what kind of grease he's looking for other than anti-corrosion so I don't think this is an EP application.111 is not a high pressure application grease. It's great for things like O-rings, and blocking water entry. I would not use it as general purpose grease for a motorcycle.
I've been using this stuff for over 40 years with great success. Absolutely love it.I use Bel Ray water proof grease on all our bikes, street and dirt, for everything. Good stuff.
Bel-Ray Waterproof Grease is aluminum complex.Bel-Ray seems to be the favorite of motorcycle techs. You’re in the UK and Silkolene, a Fuchs brand should be available.
Else, look for a overbased calcium sulfonate or aluminum complex grease. Eni Autol Top 2000 is a good pick. It’s also sold by Motorex as Grease 2000 for motorbikes and pushbikes(and Shimano sells it as their Dura-Ace grease, the same neon yellow grease they use from the factory).
