motorcraft filter good for 2oci
How about if we let the owners and their rice burners use the oil filter as many times as they want, and those of us that want to buy cheap insurance and use a new oil filter every OCI, do so? Are we all agreed?
I'm of the opinion that filters are under utilized and have a greater capacity than will be used a the recommended interval. Also a filter becomes more efficient for filtering the longer it's in use. This of course is contingent on the condition of your engine just due to the fact that he's on this board asking the question, I'm going to assume that he takes care of his vehicle I.e.keeps up on maintenance. In this case he most likely doesn't have an overly dirty or sludge motor. I think he should go ahead and leave it for the rest of the oci.
Originally Posted By: Noey
[ But then again, I'm unimpressed with anything Honda.
That we can agree on!
I have done multiple OCI's on the same filter never a problem but I am not a big fan of it either. Honestly it makes more sense on a cartridge filter because 1) the cartridge doesn't hole old oil and 2) you can easily inspect the filter and view it's condition.
KC, say it isn't so! Don't make me have to come up to your neck of the woods and re-educate you on proper oil filter use!
Filters filter better to a point the longer you use them. So a filter used twice is actually keeping your oil marginally cleaner.
On a non-sludged engine, most filters have so much filtering capacity they could be considered overkill.
The 4-6 ounces of oil that doesn't get changed is inconsequential, meaning your TBN will be a 1.9 instead of a 2.0 had you changed the filter. Whoopty doo.
I have been doing two changes per filter for 10 or 15 years and it is perfectly fine. I just try to use a better filter with better media and a silicone anti-drain back valve, for piece of mind. A decent filter can definitely handle it.
What are you saving by running clean oil thru a dirty filter? $5? What is the point? Has anyone ever had a "problem" as the result of over maintenance?
I'm also unimpressed with the "I've-been-doing-this-since-forever-with-no-problems". What are we defining as a problem? A complete engine meltdown? We're all fanatics to some extent, the extra wear on parts by dirty oil or inferior filters is why we're spending quality time on this site.
So, I change the filter at every OCI. I just don't get the rationale in not doing so.
I think the rational is that a filter is more efficient with time used. The ? Is will it plug up before the end of the 2md run.
I agree with your thinking. Great response.
Originally Posted By: BlueOvalFitter
One Filter, One OCI!
Agreed. Why mix new oil with several extra ounces of old oil? Besides I do 10K OCIs then change both filter and oil. MC filters perform very well at 10K.
+1.
I could see if someone is just plain lazy and not want to change the oil filter. Or, they are just too tight that they don't want to change the oil filter. I look at it like an oil filter is cheap insurance for an engine.
Ah well, to each his own.
Originally Posted By: ZeeOSix
One Filter, One OCI! span>
Z06, of all the other members here, I thought you would be on my side.
The multiple use of the same oil filter force is strong with this one in Z06!
2 for 1 and better filtration too. Double your foci and your car is better for it. Go buy a beer or a soda with the few dollars u save.
Depends on the OCI mileage and the filter being used. Doing 2 x 6,000 OCIs on an Ultra for instance is a no-brainer. If doing 6K OCIs with say a non-synthetic WIX or Motorcraft, then go with a new filter too.
Well, you seem to have that part correct. It does take "no brains" to use the same used oil filter for multiple OCI's.
My FU WILL be replaced at or near 10K miles with a NEW oil filter at the next OCI.
LoL ... yeah, good one with the "no brains".
But in your case since you went with a 10K OCI it makes sense to change the Ultra too since you wouldn't want to do 2 x 10K OCIs on it.
Seriously Z06, what filter do you have on your Z06 engine, and the oil brand and type you use in it? What is your OCI mileage or do you have a monitor? That would definitely be one engine that I would NEVER use a USED oil filter multiple times for an OCI.
