The best system for cold weather would be a Motor Guard ATF filter used with a Perma-Cool or equivalent sandwich adapter. The ATF filter has an element bypass orifice. One stream of oil is being cleaned and the other stream of oil is heating up the oil filter. The ATF filter will only work with a two port sandwich adapter or for ATF. A larger orifice doesn't help much because most of the restriction is in the cold element. At one time you could buy an electric blanket for the depth filters. I didn't have any problems in the Idaho winters but I drove over 30 miles to work. The VW Beetle that I used most had no under hood heat to help warm the Motor Guard.
The M-30 ATF has a 1/8" bypass orifice. You can get a lot of oil thru the bypass orifice.
Ralph
Ralph
