HTSS_TR- VSOT is much thicker than LM MoS2. I do the same shake and mix routine myself. MoS2 really leaves a lot remaining in the conatiner if you don't add oil, shake it up, pour it out, and repeat. Typically what I do is add 3 qts of oil to the sump, pour the MoS2 in, then fill the MoS2 bottle with oil about halfway and shake it. I use as much of the remaining oil as I have to get the remaining MoS2 out of the bottle. You'd be surprised how much can remain in that little bottle.
