mos2 technical reviews
Originally Posted By: Gokhan
Originally Posted By: dailydriver
Now whether or not they contain trinuclear organic moly is anyone's guess
and I'm almost certain that they would not tell you if you asked (proprietary and all, you know the drill.
No worries. Chances are that it doesn't matter if it's trinuclear, mononuclear, or dinuclear if you have a high concentration of Mo.
I think basically, say, 75 ppm Mo via trinuclear moly does the same job in wear protection, antioxidation, and friction reduction as 300 ppm Mo via dinuclear moly, but at one point (after a certain moly level) the effects saturate for both. Therefore, if you don't have trinuclear moly but have dinuclear or mononuclear moly, all you have to do is to add more moly, and you will see the same end result. The important thing is that the organic moly should contain both Mo and S; otherwise, it won't result in the coating of the metal parts with a MoS_2 film and you won't see friction-reduction and antiwear benefits.
Interesting that there are so many aftermarket organic-moly additives out there (Lubeguard, Torco, etc.). I didn't know.
The levels in their MPZ product are CRAZY high (last VOA I've seen on here it was >9999PPM!!!!!!!), as were the antimony and ZDDP levels.
The SEP is a lot more late model, catcon equipped, street car friendly, with MUCH reduced ZDDP levels, but only slightly less organic soluble moly levels.
Here is a VOA of Torco MPZ for those interested.
Fe 3
Al 15
Copper 3
Tin 169
Si 20
Moly 7603
Zn - trace
Phos - greater than 9999 -max of instrument reading capability.
Antimony- greater than 9999 - max of instrument reading capability
Viscosity 29.3
Small update on different car:
When I added Mos2 to the Corolla, I also added it to my brothers gf's car, a '98 Ford Escort w/ 190K miles. He's not a car guy at all. I told him I was adding Moly to her car and he said "ok, whatever that is". She was ok with it too, after all it is her car.
Anyways, he told me today that the car wasn't shaking as much. I went out there with him and observed the same. In addition, the valvetrain noise there before is all but gone. They've driven it about 125 miles since the addition of Mos2.
The Corolla is acting the same, quieter/smoother operation. It's been about 350 miles so far. Just starting to test mpg.
It's been 1500 miles since the addition of Mos2 in our Corolla. Sometimes I can't believe how smooth the engine is running. Keeping track of MPG, but nothing conclusive. Since my shift changed at work(courier), my driving is all over the place. My previous tank returned 33.5mpg. Driving consisted of mostly city, ~30 minutes of idling and constant A/C use. I thought this was pretty good. I would really have to do an exact trip though w/ and without the Mos2 to get definitive data.
Two weeks ago I changed the oil for my fiancee's mom's car. It's an '05 Corolla w/ 127,000 miles. Used Rotella T5 and 1/2 can Mos2. For awhile this car has been a little "noisy" to me, noisier than our Corolla(same engine). I attribute this to a very bad habit she has. She has her foot on the gas when she starts the car
The noise isn't a knock or anything, sounds more like a tap. Car runs good though. Anyways, saw her today and she's driven it 500 miles since the oil change. Her motor now sounds like our's does, nice and quiet. If I could only convince her to leave her foot off the gas on startup!
The Mos2 continues to impress. BTW, I also like using LG Biotech. However, the Biotech didn't do anything for the noise in that car.
If you grew up with a carburated car I can understand why you feel the need to have your foot on the gas.
My 1983 Ford LTD that I learned to drive with had character. I was the only one who could start it. Even my father would pull the intake off and manually choke it with a screwdriver to get it started in the morning.
One pump of the gas peddle, then hold it down 1/4" and she would start every morning first time. Anything more she would flood and you would have to wait a few minutes to try again.
Cars that have computers and all that jazz just don't have the same character.
BTW, the MOS2 that I have added to 3 cars is going just peachy keen. I look forward to doing used oil analysis on a couple of them just to see how things are working.
Originally Posted By: HTSS_TR
Lubro-Moly MoS2 at Napa auto parts. Part number LM2009.
This.
I did my 2nd OCI w/LM MoS2 & Syntec 5W40 in my high mileage Audi 2.8 30v last night. Besides the aforementioned improvements in drivability, my oil consumption over the previous 6k was less than 1qt(normally ~1.5qts over the same interval). Good stuff, indeed.
how much are they you know?
and have you use liqui moly cera tec?
The reason that many people tried MoS2 was good reviews and low price. If you try MoS2 and don't get good result as expected, then you will be out $4.xx which is about a Latte at Starbucks.
have you tried cera tec?
it says its like ceramic + mos2 but it stays in ur engine for 30,000miles. i dont know which one to get
I'd use the moly. There's been talk that the ceramic additives find their way into the combustion chamber and can foul plugs. People have reported such good results with the MoS2 why tempt fate?
I went to liqui moly warehouse today i was passing by one by accident. i talk to the eastcoast sales guy. i asked him about cera tec, and he brought me a box of instruments for a demonstration. and he did mention me about foul in engine parts. but he told me that its a nano tech so no need to worry.
Originally Posted By: zyxelenator
where did you find Ceratech?
{removed non -site sponsor links}
its about 30$ idk if i am ganna get it online because i found a warehouse around me lol.
Yeah I know that website...50 bucks
i might stop by on monday and talk to the sales guy about it.
idk how much it is for the original cost. but could get that price lower.
I found this quote on the Blauparts.com website after I'd been using LM MoS2 in my Audi engine. Interesting how it pretty much sums up my own experience...
Quote:
We've use this additive in our own service facility and tests have revealed significant reduction in oil consumption on Audi VW vehicles equipped with 2.8 liter V6 engines. Even on V6 engines which previously had an abnormal oil consumption problem. We've also noticed a measurable fuel mileage increase!
FWIW, I'm a career Audi dealership employee and I'm fully aware of VWaG's position on the use of oil additives in their engines. Two of my coworkers also drive high-mileage 2.8 V6s and both of them bought LM MoS2 after hearing about my experience...their results have been remarkably similar. Quite frankly, if I were permitted to recommend this product to my clients...I would.
