I know that Valvoline and Mobil are OEM suppliers. This doesn't mean that there aren't other suppliers. So, I wouldn't worry about either!
The word synthetic is a marketing term. In case of an oil, it means that the basestock is synthetic. But, rarely do they tell you how much of the bottle is basestock. Bottle label is not worth debating about!
http://www.pzlqs.com/Tech/Pdsheet/DomesticMarketing/Gear&Transmission/pdf/ATF4.pdf
Compare ATF+4 from Pennzoil and Valvoline:
Visc at 100: Pzl=7.71 Valv=7.55 ValvMSDS~7.3-7.8
Visc index: 198 for both
Flash point: Pzl=410 Valv=385
-40 cst: Pzl=9300 Valv=9000 ValvMSDS~ Pour point: -48 for both
Visc @ +40: Pzl=35.13 Valv=34.13
Valvoline additives: 460=phos, 690=Calcium, Z=0, Boron=140
SAE ATF+4 test fluid: 460=phos, 690=calcium, Boron=130, 100visc=7.43, -40visc=9490, Flashpoint 417,
Valvoline MSDS ingredients:
Basestock 75-85%
VII 8-18%
Transmission fluid additive: 2.7-13%
POLYALKYLMETHACRYLATE 4.4-14
In the Mobil/Mopar ATF+4 MSDS, no ingredients are given except ACRYLATE POLYMER 10-20%. Thats a pretty big range!
Mobil products numbers: 520270-00, 97W904 and 522813-00, 97Z556. Maybe you can match that to something on the Mopar bottle? Break out the UV or black lightbulbs!
If the blending specs are so broad, we would have to believe that any fluid blended within the range should pass the minimum Chrysler requirements.
Now all we need is datasheets for Supertech, Mobil, and Advancedauto ATF+4.
